메인 콘텐츠로 스킵하기
소개
We dismantled the Acer Iconia One 7 and found it to be extremely repairable with only 8 components.
  1. Reference photos with packaging. Reference photos with packaging. Reference photos with packaging.
    • Reference photos with packaging.
  2. Entry method is to remove the rear bathtub case, the seal is easy to break with opening tools.
    • Entry method is to remove the rear bathtub case, the seal is easy to break with opening tools.
    • The bathtub case is attached to the front display panel by soft plastic clips and without adhesive.
    • A spring connector connects the motherboard to the bathtub case so no need to worry about damaging fragile cables during removal.
  3. The battery cable runs short and requires a careful and precise wiggle to remove its connection from the motherboard. Only two adhesive pull tabs secure the battery. This is preferred over adhesive which requires heat and prying to separate. The adhesive strips will need to be replaced after removal.
    • The battery cable runs short and requires a careful and precise wiggle to remove its connection from the motherboard.
    • Only two adhesive pull tabs secure the battery. This is preferred over adhesive which requires heat and prying to separate.
    • The adhesive strips will need to be replaced after removal.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Layer of components removable upon opening: power/volume button cable, loudspeaker.
    • Layer of components removable upon opening: power/volume button cable, loudspeaker.
    • The power/volume button cable is lightly secured with adhesive.
    • Two Phillips #0 screws secure the loudspeaker housing.
  6. The display, digitizer, and camera cables can be disconnected without removing the motherboard. The motherboard is secured to the display frame by three Phillips #0 screws.
    • The display, digitizer, and camera cables can be disconnected without removing the motherboard.
    • The motherboard is secured to the display frame by three Phillips #0 screws.
    • The Micro-USB port, headphone jack and microphone are soldered to the motherboard. These are common failure points and it would be better if they could be individually replaced.
    • The front and rear camera are tethered and will need to be replaced together if one where to fail.
  7. Motherboard reference photos. Motherboard reference photos.
    • Motherboard reference photos.
  8. The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool. The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool.
    • The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool.
  9. The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair): LCD and front glass are not fused and can be replaced individually.
    • The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
    • LCD and front glass are not fused and can be replaced individually.
    • Battery is easy to replace.
    • Modular design allows replacement of many individual parts.
    • Standard Phillips screws used throughout.
    • High wear components soldered in place, which increases replacement costs.
    • Manufacturer does not provide user-accessible repair documentation.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Blake Klein
회원 가입일: 2017년 01월 29일
44,138 평판
안내서 48개 작성하였습니다
I have an Acer Iconia tablet A500, 32GB RAM, 1GB ROM
I would like to increase my ROM to 4GB ROM, is it possible.
Can you recommend someone or a place that can do this for me?
Thanks, Ginger
email address: ginger41558@outlook.com
ginger41558 - 답글
I have used it very little, sat quietly in a drawer - when I decided to use it, it won’t power up! Sometimes it shows a splash screen with one word on it - ACER (if I remember right). Any idea what might be going on, I’d be grateful - would even give it to someone to revive and use
ruralwannabe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 81
전체 시간: 2,317
