주요 콘텐츠로 건너뛰기
Acer Iconia One 8 Battery Replacement
필요한 것
  1. Acer Iconia One 8 Battery Replacement, Battery: 1 단계, 이미지 1/2 Acer Iconia One 8 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: 3 단계, 이미지 1/1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: 4 단계, 이미지 1/1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Josh Cooper
회원 가입일: 04/13/17
319 평판
안내서 3개 작성하였습니다
University of Memphis, Team S1-G1, Kim Spring 2017 University of Memphis, Team S1-G1, Kim Spring 2017 회원
UM-KIM-S17S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 19
전체 시간: 2,882
