주요 콘텐츠로 건너뛰기
Acer Iconia One 8 Front Camera Replacement
필요한 것
  1. Acer Iconia One 8 Front Camera Replacement, Screen: 1 단계, 이미지 1/2 Acer Iconia One 8 Front Camera Replacement, Screen: 1 단계, 이미지 2/2
    • Begin by opening the back panel.
    • Wedge a plastic opening tool in between the front and back shell and gently separate.
  2. Acer Iconia One 8 Front Camera Replacement: 2 단계, 이미지 1/3 Acer Iconia One 8 Front Camera Replacement: 2 단계, 이미지 2/3 Acer Iconia One 8 Front Camera Replacement: 2 단계, 이미지 3/3
    • Peel back all pieces of tape indicated in picture.
    • There are three pieces of tape total (2 Black and 1 Silver).
  3. Acer Iconia One 8 Front Camera Replacement: 3 단계, 이미지 1/3 Acer Iconia One 8 Front Camera Replacement: 3 단계, 이미지 2/3 Acer Iconia One 8 Front Camera Replacement: 3 단계, 이미지 3/3
    • Disconnect all cables from the device.
    • There should be 5 total.
  4. Acer Iconia One 8 Front Camera Replacement: 4 단계, 이미지 1/3 Acer Iconia One 8 Front Camera Replacement: 4 단계, 이미지 2/3 Acer Iconia One 8 Front Camera Replacement: 4 단계, 이미지 3/3
    • Remove the nine 3mm screws using the Phillips #000 screwdriver.
  5. Acer Iconia One 8 Front Camera Replacement: 5 단계, 이미지 1/1
    • Remove and separate the back plating (top) from the glass screen (bottom).
  6. Acer Iconia One 8 Front Camera Replacement, Motherboard: 6 단계, 이미지 1/2 Acer Iconia One 8 Front Camera Replacement, Motherboard: 6 단계, 이미지 2/2
    • Disconnect the metal tabs connecting the battery to the motherboard frame.
  7. Acer Iconia One 8 Front Camera Replacement: 7 단계, 이미지 1/2 Acer Iconia One 8 Front Camera Replacement: 7 단계, 이미지 2/2
    • Disconnect the cable for the back camera.
  8. Acer Iconia One 8 Front Camera Replacement: 8 단계, 이미지 1/1
    • Flip the metal plating to reveal the front camera.
  9. Acer Iconia One 8 Front Camera Replacement: 9 단계, 이미지 1/2 Acer Iconia One 8 Front Camera Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to carefully remove the front camera from the adhesive on the motherboard.
  10. Acer Iconia One 8 Front Camera Replacement: 10 단계, 이미지 1/3 Acer Iconia One 8 Front Camera Replacement: 10 단계, 이미지 2/3 Acer Iconia One 8 Front Camera Replacement: 10 단계, 이미지 3/3
    • Flip the device back over.
    • Remove the motherboard from the metallic frame by feeding the back camera and front camera cable through the port.
    • Remove the front camera from the device.
  11. Acer Iconia One 8 Front Camera Replacement, Front Camera: 11 단계, 이미지 1/3 Acer Iconia One 8 Front Camera Replacement, Front Camera: 11 단계, 이미지 2/3 Acer Iconia One 8 Front Camera Replacement, Front Camera: 11 단계, 이미지 3/3
    • Separate the front-facing camera from the back camera.
    • The two cameras are connected by glue and can be pulled apart.
결론
Dustin Newland
회원 가입일: 11/06/19
343 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G2, Stella Fall 2019 IUPUI, Team S1-G2, Stella Fall 2019 회원
IUPUI-STELLA-F19S1G2
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 115
