주요 콘텐츠로 건너뛰기
Acer Iconia Tab 8 A1-860 Battery Replacement
필요한 것
  1. Acer Iconia Tab 8 A1-860 Battery Replacement, Rear Case: 1 단계, 이미지 1/2 Acer Iconia Tab 8 A1-860 Battery Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Battery Replacement: 2 단계, 이미지 1/1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Battery Replacement: 4 단계, 이미지 1/3 Acer Iconia Tab 8 A1-860 Battery Replacement: 4 단계, 이미지 2/3 Acer Iconia Tab 8 A1-860 Battery Replacement: 4 단계, 이미지 3/3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
결론
Stephanie Nelson
회원 가입일: 05/05/16
101 평판
안내서 1개 작성함
iFixit, Team 1-1, Suovanen Spring 2016 iFixit, Team 1-1, Suovanen Spring 2016 회원
FIX-SUOVANEN-S16S1G1
3 회원들
안내서 1개 작성하였습니다
댓글 2개
The model I worked on has two flat black bands running across the battery from one side to the other. They appear to be wiring connecting each side of the electronics because they are connected to sockets on both sides. Didn't want to proceed until I have more info. I have a jpg of the setup if that would help anyone (or would help me).
Keith Riggs - 답글
Is this identical to the 8 A1 850? Not finding any instructions or videos on that particular model. I can’t see a notch or anything to use as a starting point to open the tablet. Where and how do you start to open it?
David - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 4,962
