주요 콘텐츠로 건너뛰기
Acer Iconia Tab A200 Battery Replacement
필요한 것
  1. Acer Iconia Tab A200 Battery Replacement, Battery: 1 단계, 이미지 1/2 Acer Iconia Tab A200 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Battery Replacement: 2 단계, 이미지 1/2 Acer Iconia Tab A200 Battery Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Battery Replacement: 3 단계, 이미지 1/2 Acer Iconia Tab A200 Battery Replacement: 3 단계, 이미지 2/2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Battery Replacement: 4 단계, 이미지 1/2 Acer Iconia Tab A200 Battery Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Battery Replacement: 5 단계, 이미지 1/2 Acer Iconia Tab A200 Battery Replacement: 5 단계, 이미지 2/2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jaimie Payne
회원 가입일: 03/06/16
477 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G5
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
Michael Burlovich - 답글
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
Gloria Regester - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,763
