소개
The dual speakers are used to play sound from the device. The wiring for the speakers may also be difficult to see as they are black and blends in with the case. If you are having trouble see the wires try using a flashlight.
필요한 것
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
거의 끝나갑니다!
결론
