주요 콘텐츠로 건너뛰기
Acer Iconia Tab A500 Battery Replacement
필요한 것
  1. Acer Iconia Tab A500 Battery Replacement, Back Case: 1 단계, 이미지 1/1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Battery Replacement: 2 단계, 이미지 1/1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Acer Iconia Tab A500 Battery Replacement: 4 단계, 이미지 1/1
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Kyle Libby
회원 가입일: 04/07/14
1,006 평판
안내서 7개 작성하였습니다
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 회원
CPSU-REGAN-S14S7G23
4 회원들
안내서 19개 작성하였습니다
댓글 2개
I just replaced my battery because it kept draining and the new battery started to charge but now it won’t charger at all so what can be wrong?
misscris0611 - 답글
Hi l have had my acer tablet for over 10 years and the acer iconiatab a500 as no been turned on for over 10 years and it is not cargering
Linda George - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 17
전체 시간: 11,444
