소개
This repair guide will help you with replacing the battery on your Acer Iconia Tab A500. Battery replacement might be needed when the battery inside the Acer Iconia Tab A500 is not functioning accordingly.
필요한 것
Remove the 5mm screws that are securing the battery to the rest of the tablet.
Use the Phillips #00 Screwdriver to remove the 5mm screws.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 2개
I just replaced my battery because it kept draining and the new battery started to charge but now it won’t charger at all so what can be wrong?
Hi l have had my acer tablet for over 10 years and the acer iconiatab a500 as no been turned on for over 10 years and it is not cargering
