주요 콘텐츠로 건너뛰기
Acer Iconia Tab A500 Speakers Replacement
필요한 것
  1. Acer Iconia Tab A500 Speakers Replacement, Back Case: 1 단계, 이미지 1/1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Speakers Replacement: 2 단계, 이미지 1/1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Speakers Replacement, Speakers: 3 단계, 이미지 1/1
    • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
    • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
  4. Acer Iconia Tab A500 Speakers Replacement: 4 단계, 이미지 1/2 Acer Iconia Tab A500 Speakers Replacement: 4 단계, 이미지 2/2
    • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  5. Acer Iconia Tab A500 Speakers Replacement: 5 단계, 이미지 1/1
    • Unfortunately, the top speaker is a wedged under the motherboard.
    • To get this speaker out, use the spudger and gently pry it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle Libby
회원 가입일: 04/07/14
1,006 평판
안내서 7개 작성하였습니다
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 회원
CPSU-REGAN-S14S7G23
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 1,993
