주요 콘텐츠로 건너뛰기
Acer Iconia Tab A500 USB Port Replacement
필요한 것
  1. Acer Iconia Tab A500 USB Port Replacement, Back Case: 1 단계, 이미지 1/1
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 USB Port Replacement: 2 단계, 이미지 1/1
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 USB Port Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Acer Iconia Tab A500 USB Port Replacement: 4 단계, 이미지 1/1
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  5. Acer Iconia Tab A500 USB Port Replacement, USB Port: 5 단계, 이미지 1/1
    • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
  6. Acer Iconia Tab A500 USB Port Replacement: 6 단계, 이미지 1/1
    • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
  7. Acer Iconia Tab A500 USB Port Replacement: 7 단계, 이미지 1/1
    • Disconnect the blue cable by gently lifting the flap.
    • Remove the indicated 2mm screw holding the speaker in place.
  8. Acer Iconia Tab A500 USB Port Replacement: 8 단계, 이미지 1/1
    • Pull up the metal panel just enough to allow access, then remove the USB port.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sam Macy
회원 가입일: 04/01/14
1,161 평판
안내서 1개 작성함
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014 회원
CPSU-REGAN-S14S7G23
4 회원들
안내서 19개 작성하였습니다
댓글 2개
Awesome I love the visual of the steps. Thank you!
_Samsunz
samiam6 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,513
