주요 콘텐츠로 건너뛰기
Acer Iconia Tab A501 Docking Port Replacement
필요한 것
  1. Acer Iconia Tab A501 Docking Port Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Iconia Tab A501 Docking Port Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Iconia Tab A501 Docking Port Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Docking Port Replacement: 2 단계, 이미지 1/1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Docking Port Replacement, Docking Port: 3 단계, 이미지 1/3 Acer Iconia Tab A501 Docking Port Replacement, Docking Port: 3 단계, 이미지 2/3 Acer Iconia Tab A501 Docking Port Replacement, Docking Port: 3 단계, 이미지 3/3
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Docking Port Replacement: 4 단계, 이미지 1/3 Acer Iconia Tab A501 Docking Port Replacement: 4 단계, 이미지 2/3 Acer Iconia Tab A501 Docking Port Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to flip up the locking mechanism for the ribbon cable on the docking port board that is flat, white, and folded.
    • Detach the folded, white ribbon cable on the docking port board.
  5. Acer Iconia Tab A501 Docking Port Replacement: 5 단계, 이미지 1/2 Acer Iconia Tab A501 Docking Port Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
  6. Acer Iconia Tab A501 Docking Port Replacement: 6 단계, 이미지 1/2 Acer Iconia Tab A501 Docking Port Replacement: 6 단계, 이미지 2/2
    • Remove the docking port.
결론
Daksh Malhotra
회원 가입일: 07/08/19
1,383 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 145
