주요 콘텐츠로 건너뛰기
Acer Iconia Tab A501 Touch Screen/Glass Replacement
필요한 것
  1. Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 2 단계, 이미지 1/1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Display: 3 단계, 이미지 1/1
    • Remove all tape from the device.
  4. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 4 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 4 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 4 단계, 이미지 3/3
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
  5. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 5 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 5 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 5 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
    • Take out the battery.
  6. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 6 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 6 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 6 단계, 이미지 3/3
    • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the folded, white ribbon cable.
    • Remove the folded, white cable.
  7. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 7 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 7 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 7 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
    • Remove the docking port.
  8. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 8 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 8 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 8 단계, 이미지 3/3
    • In this step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly in from the docking port.
  9. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 9 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 9 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 9 단계, 이미지 3/3
    • Unscrew the 3.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
    • Unscrew the 4.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
  10. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 10 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 10 단계, 이미지 2/2
    • Remove the speakers.
  11. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 11 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 11 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 11 단계, 이미지 3/3
    • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the straight, white ribbon cable.
    • Remove the straight, white ribbon cable.
  12. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 12 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 12 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 12 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two 4.0 mm Philips screws attaching the metal plate, USB board, and device.
    • Remove the metal plate.
  13. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 13 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 13 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 13 단계, 이미지 3/3
    • Use the Halberd Spudger to carefully pop up and take out the ports.
  14. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 14 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 14 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 14 단계, 이미지 3/3
    • Use care in the next step.
    • Use the wide, flat end of the standard Spudger to disconnect the display connector from the large, metal port next to the battery space.
  15. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 15 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 15 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 15 단계, 이미지 3/3
    • Use the flat end of the standard Spudger to disconnect the two small, rotatable connectors attached to the wireless adapter.
  16. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 16 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 16 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 16 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
  17. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 17 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 17 단계, 이미지 2/2
    • Carefully slide the adapter out to remove it.
  18. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 18 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 18 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 18 단계, 이미지 3/3
    • Use the wide end of the standard Spudger to take off the rotatable connector to the 3g antenna below the rear-facing camera.
  19. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 19 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 19 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 19 단계, 이미지 3/3
    • Use the angled tweezers to disconnect the cable with red wires from the beige connector opposite the docking port.
  20. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 20 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 20 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 20 단계, 이미지 3/3
    • The charging port may be taped from underneath and need a bit of force to take out.
    • Use the angled tweezers to remove the charging port.
  21. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 21 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 21 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 21 단계, 이미지 3/3
    • Use the tweezers to remove the white touchscreen connector with multi-colored wires from the black port just below the power buttons on the motherboard.
  22. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 22 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 22 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 22 단계, 이미지 3/3
    • Use the plastic opening tool to flip up the locking mechanism for the wide, white port for the thin, orange-brown touchscreen cable just above the charging port.
    • Remove the touchscreen board.
  23. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 23 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 23 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 23 단계, 이미지 3/3
    • Use the angled tweezers to disconnect two microphone connectors, which are above the orange-brown touchscreen connector and next to the battery space.
  24. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 24 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 24 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 24 단계, 이미지 3/3
    • Use the plastic opening tool to flip up the locking mechanism to the white front camera port just above the rear-facing camera.
    • Disconnect the camera cable from the motherboard.
  25. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 25 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 25 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew the four 4.0 mm Phillips head screws holding the motherboard in place.
  26. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 26 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 26 단계, 이미지 2/2
    • Remove the motherboard.
  27. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 27 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 27 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 27 단계, 이미지 3/3
    • Remove the two microphones in the middle of the side opposite the docking port.
  28. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 28 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 28 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to unscrew the 3.0 mm Phillips head screw holding the thin metal plate to the device near the Micro-HDMI port.
    • Use the Phillips #1 screwdriver to unscrew the 4.0 mm Phillips head screw near the orange-brown touchscreen cable.
  29. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 29 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 29 단계, 이미지 2/2
    • Move all wires off of the thin, metal plate.
  30. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 30 단계, 이미지 1/1
  31. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 31 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 31 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 31 단계, 이미지 3/3
    • The antennae in the next step are attached with adhesive.
    • Remove the three antennae along the shorter sides of the device.
  32. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 32 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 32 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 32 단계, 이미지 3/3
    • Carefully insert the Jimmy between the display and the glass to break the glue seal.
    • Move the Jimmy all the way around the device.
  33. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 33 단계, 이미지 1/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 33 단계, 이미지 2/3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: 33 단계, 이미지 3/3
    • Continue moving the Jimmy around the device until the glue no longer holds the display in place.
    • Remove the display.
  34. Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Touch Screen/Glass: 34 단계, 이미지 1/2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Touch Screen/Glass: 34 단계, 이미지 2/2
    • Use the Jimmy to carefully remove the front camera from the front cover of the tablet.
결론
Daksh Malhotra
회원 가입일: 07/08/19
1,383 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 253
