주요 콘텐츠로 건너뛰기
Acer Iconia Tab A501 Wireless Adapter Replacement
필요한 것
  1. Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Wireless Adapter Replacement: 2 단계, 이미지 1/1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: 3 단계, 이미지 1/3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: 3 단계, 이미지 2/3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: 3 단계, 이미지 3/3
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Wireless Adapter Replacement: 4 단계, 이미지 1/1
    • Remove all tape covering the wireless adapter.
  5. Acer Iconia Tab A501 Wireless Adapter Replacement: 5 단계, 이미지 1/3 Acer Iconia Tab A501 Wireless Adapter Replacement: 5 단계, 이미지 2/3 Acer Iconia Tab A501 Wireless Adapter Replacement: 5 단계, 이미지 3/3
    • Use the flat end of the standard Spudger to disconnect the two small rotatable connectors attached to the wireless adapter.
  6. Acer Iconia Tab A501 Wireless Adapter Replacement: 6 단계, 이미지 1/2 Acer Iconia Tab A501 Wireless Adapter Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
  7. Acer Iconia Tab A501 Wireless Adapter Replacement: 7 단계, 이미지 1/2 Acer Iconia Tab A501 Wireless Adapter Replacement: 7 단계, 이미지 2/2
    • Carefully slide the adapter out to remove it.
결론
Daksh Malhotra
회원 가입일: 07/08/19
1,383 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 330
