소개
If you forgot your password, PIN, pattern drill, or if you have problem with your Android OS, you can make a Factory / Hard reset.
동영상 개요
Power off the tablet. Press and hold the Volume Up and the Power button. After 3 seconds release the Power On button but continue holding the Volume Up button. In the Select Boot Mode use the Volume Up/Down keys to navigate and the Power button to select the desired option.
[SD Image Update Mode]
wipe data/factory reset
Yes - delete all user data
Reboot system now.
Your tablet will reboot and go to the Welcome screen.
다른 41명이 해당 안내서를 완성하였습니다.
댓글 23개
This is not workin it keep saying enter the email .... n when dun its still not going in
I did this and the tablet is stuck at the logo !
I have done this. But I'm stuck at email address I use when i first bought. I don't remember my email address. What can I do
Yep I am having the same problem and have done all kinds of searching on how to override it or some other fix...
