소개
This guide will give you a step by step process for replacing the screen of an Acer Iconia W3-810 in the case of a screen failure. This guide can be used if the screen is cracked due to physical damage or burns out from excessive use.
필요한 것
Place the tablet face down on a flat surface with the charger facing toward you.
Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
Disconnect the speaker cord from the motherboard by carefully prying it out with a plastic opening tool.
다른 3명이 해당 안내서를 완성하였습니다.
