주요 콘텐츠로 건너뛰기
Acer Iconia W510 Vibration Motor Replacement
필요한 것
  1. Acer Iconia W510 Vibration Motor Replacement, Rear Cover: 1 단계, 이미지 3개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Rear Cover: 1 단계, 이미지 3개 중 2개 Acer Iconia W510 Vibration Motor Replacement, Rear Cover: 1 단계, 이미지 3개 중 3개
    • Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
    • Give the tool a twist to the left to start separating the clips.
    • Work your way to the corner, prying and twisting to pop the clips as you go.
  2. Acer Iconia W510 Vibration Motor Replacement, Right Side: 2 단계, 이미지 3개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Right Side: 2 단계, 이미지 3개 중 2개 Acer Iconia W510 Vibration Motor Replacement, Right Side: 2 단계, 이미지 3개 중 3개
    • Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
    • Continue as before, prying and twisting to release the catches.
  3. Acer Iconia W510 Vibration Motor Replacement, Top Edge: 3 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Top Edge: 3 단계, 이미지 2개 중 2개
    • Continue along the top edge as before
    • When you get to the corner, be careful not to insert the tool in the space below the power on symbol. There is a delicate clip there that is easy to break if you're prying with the tool. (Yes, I'm speaking from experience. Don't be me.)
  4. Acer Iconia W510 Vibration Motor Replacement, Left Side: 4 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Left Side: 4 단계, 이미지 2개 중 2개
    • Unclip the left side of the tablet.
  5. Acer Iconia W510 Vibration Motor Replacement, Bottom Edge: 5 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Bottom Edge: 5 단계, 이미지 2개 중 2개
    • Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
    • And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
  6. Acer Iconia W510 Vibration Motor Replacement: 6 단계, 이미지 1개 중 1개
    • The rear cover is removed.
  7. Acer Iconia W510 Vibration Motor Replacement, Unplug the Tablet Battery: 7 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Unplug the Tablet Battery: 7 단계, 이미지 2개 중 2개
    • Peel back the tape securing the battery connector.
  8. Acer Iconia W510 Vibration Motor Replacement: 8 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement: 8 단계, 이미지 2개 중 2개
    • Grasp the plug by the tabs on either side and pull it straight out from the connector.
  9. Acer Iconia W510 Vibration Motor Replacement, Charging Port Disconnection: 9 단계, 이미지 3개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Charging Port Disconnection: 9 단계, 이미지 3개 중 2개 Acer Iconia W510 Vibration Motor Replacement, Charging Port Disconnection: 9 단계, 이미지 3개 중 3개
    • Unstick the grounding tape from the charging connector.
  10. Acer Iconia W510 Vibration Motor Replacement: 10 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Using a spudger, flip up the latch securing the charge port flex cable.
  11. Acer Iconia W510 Vibration Motor Replacement: 11 단계, 이미지 1개 중 1개
    • Grasp the pull tab on the flex cable and use it to pull the cable out of the connector.
  12. Acer Iconia W510 Vibration Motor Replacement: 12 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement: 12 단계, 이미지 2개 중 2개
    • The flex cable is lightly adhered to the display frame, so use a spudger to separate it.
  13. Acer Iconia W510 Vibration Motor Replacement, Vibrator Motor Disconnection: 13 단계, 이미지 3개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Vibrator Motor Disconnection: 13 단계, 이미지 3개 중 2개 Acer Iconia W510 Vibration Motor Replacement, Vibrator Motor Disconnection: 13 단계, 이미지 3개 중 3개
    • Remove the two 2.1mm Phillips screws.
  14. Acer Iconia W510 Vibration Motor Replacement: 14 단계, 이미지 1개 중 1개
    • Flip the cable assembly over carefully, as it is still adhered to the frame by a thin strip of flex cable. Be careful not to break that strip.
  15. Acer Iconia W510 Vibration Motor Replacement: 15 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement: 15 단계, 이미지 2개 중 2개
    • Unplug the vibration motor from the charging port circuit board.
  16. Acer Iconia W510 Vibration Motor Replacement, Vibration Motor: 16 단계, 이미지 2개 중 1개 Acer Iconia W510 Vibration Motor Replacement, Vibration Motor: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With a pair of tweezers, lift the vibration motor out of its mounting bracket.
  17. Acer Iconia W510 Vibration Motor Replacement: 17 단계, 이미지 1개 중 1개
    • The vibration motor is now free.
결론
작성자
2다른 기여자 명과 함께
Jerry Wheeler
회원 가입일: 03/21/22
83,150 평판
안내서 71개를 작성함
Oregonians Oregonians 회원
Community
9 회원들
안내서 359개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 86
