주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-44-R70B Fan Replacement
필요한 것
  1. Acer Nitro 5 AN515-44-R70B Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Make sure the laptop is off and unplugged before beginning the fan replacement
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-44-R70B Fan Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the eleven M2.5x6.0 size screws holding the back cover in place.
  3. Acer Nitro 5 AN515-44-R70B Fan Replacement: 3 단계, 이미지 1/2 Acer Nitro 5 AN515-44-R70B Fan Replacement: 3 단계, 이미지 2/2
    • Carefully remove the back shell from the device.
    • Do not be too forceful as you could damage the shell.
  4. Acer Nitro 5 AN515-44-R70B Fan Replacement: 4 단계, 이미지 1/1
    • For extra caution slide out the battery cable from its connector using your fingers.
  5. Acer Nitro 5 AN515-44-R70B Fan Replacement: 5 단계, 이미지 1/1
    • Using your fingers, slide out the two fan cables from their connectors.
  6. Acer Nitro 5 AN515-44-R70B Fan Replacement: 6 단계, 이미지 1/2 Acer Nitro 5 AN515-44-R70B Fan Replacement: 6 단계, 이미지 2/2
    • Remove the gaffer tape next to the fan.
  7. Acer Nitro 5 AN515-44-R70B Fan Replacement: 7 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the four M2.5x6.0 size screws holding the fan assembly in place.
    • You can now remove the old fans and replace them with new ones.
결론
Ilyass Sellouf
회원 가입일: 01/15/24
145 평판
안내서 1개 작성함
York University, Team 1-25, O'Regan Winter 2024 York University, Team 1-25, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S1G25
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 79
전체 시간: 174
