주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-44-R70B Fan Replacement
필요한 것
  1. Acer Nitro 5 AN515-44-R70B Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is off and unplugged before beginning the fan replacement
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-44-R70B Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the eleven M2.5x6.0 size screws holding the back cover in place.
  3. Acer Nitro 5 AN515-44-R70B Fan Replacement: 3 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-44-R70B Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully remove the back shell from the device.
    • Do not be too forceful as you could damage the shell.
  4. Acer Nitro 5 AN515-44-R70B Fan Replacement: 4 단계, 이미지 1개 중 1개
    • For extra caution slide out the battery cable from its connector using your fingers.
  5. Acer Nitro 5 AN515-44-R70B Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Using your fingers, slide out the two fan cables from their connectors.
  6. Acer Nitro 5 AN515-44-R70B Fan Replacement: 6 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-44-R70B Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the gaffer tape next to the fan.
  7. Acer Nitro 5 AN515-44-R70B Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the four M2.5x6.0 size screws holding the fan assembly in place.
    • You can now remove the old fans and replace them with new ones.
결론
작성자
1다른 기여자 명과 함께
Ilyass Sellouf
회원 가입일: 01/15/24
145 평판
안내서 1개를 작성함
1가이드 댓글
Im having trouble taking off the back shell, since the tolerances are too low to get anything in there besides the back with the charger port, in which case the part covering the hinge just pops off, instead of the back cover, is there anything I can do in this situation or do I just need something thinner to pry it off? I've been using an old credit card btw.
Diego Martinez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 68
전체 시간: 1,310
