주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-52FA RAM Replacement
필요한 것
  1. Acer Nitro 5 AN515-53-52FA RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Make sure the laptop is off and unplugged before starting.
    • Flip the laptop upside down so the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-52FA RAM Replacement: 2 단계, 이미지 1/3 Acer Nitro 5 AN515-53-52FA RAM Replacement: 2 단계, 이미지 2/3 Acer Nitro 5 AN515-53-52FA RAM Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the single 9mm screw holding the tray in place.
    • Remove the RAM tray cover by prying on the opening with a spudger.
  3. Acer Nitro 5 AN515-53-52FA RAM Replacement: 3 단계, 이미지 1/2 Acer Nitro 5 AN515-53-52FA RAM Replacement: 3 단계, 이미지 2/2
    • Locate the silver clips holding the RAM in place
    • Push the silver clips down away from the RAM. The ram should pop out at an angle.
  4. Acer Nitro 5 AN515-53-52FA RAM Replacement: 4 단계, 이미지 1/2 Acer Nitro 5 AN515-53-52FA RAM Replacement: 4 단계, 이미지 2/2
    • Gently slide RAM out of the slot.
    • When inserting new RAM make sure to install it in the correct orientation.
결론
Alfredo Prieto
회원 가입일: 09/01/22
827 평판
안내서 5개 작성하였습니다
Gateway, Team 1-3, Pee Fall 2022 Gateway, Team 1-3, Pee Fall 2022 회원
GCC-PEE-F22S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 40
전체 시간: 642
