소개
Use this guide to replace the Battery in the Acer Nitro 5 Acer Nitro 5 AN515-53-55G9. This laptop has a 4-cell battery, with this guide you can replace the battery if it is damaged or not working.
Flip the laptop upside down so that the bottom is facing up.
Identify the RAM tray on the bottom of the laptop.
Identify the Hard Drive tray to the left side of the laptop.
Remove screw with a #0 Philips screwdriver.
Lift up the Slot covering using a spunger.
You didn't tell me how to properly disconnect my hard drive! Now it's disconnected inside of the %#*@ machine and I don't know where the !&&* the cable goes!
Removing the back shell of the computer and it will look like this.
The battery for the device is located at the bottom middle of the laptop at this orientation.
One part you missed was to tell everyone that the HDD would still be attached to the back shell. I removed the shell and promptly ripped out my HDD cable. Now having to order a new cable…
I just translated the instructions. but I'm sorry. what should i write instead
다른 10명이 해당 안내서를 완성하였습니다.
댓글 한 개
For future articles, you might consider adding a section describing how to “initialize” the replacement battery pack to maximize life.
Either that, or at least mention initialization plays a part in maximizing battery life and point to another article that provides reliable information.
Thanks for the article.
