주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-55G9 RAM Replacement
필요한 것
  1. Acer Nitro 5 AN515-53-55G9 RAM Replacement, RAM: 1 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement, RAM: 1 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 RAM Replacement: 2 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement: 2 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 RAM Replacement: 3 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement: 3 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement: 3 단계, 이미지 3/3
    • Locate the silver clips holding the RAM tray.
    • Push the silver pins holding the RAM tray down away from RAM. Slight pressure may be required. The RAM tray should pop up at an angle.
  4. Acer Nitro 5 AN515-53-55G9 RAM Replacement: 4 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement: 4 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 RAM Replacement: 4 단계, 이미지 3/3
    • Slide ram card out of its groove.
    • When installing the new RAM card, make sure to slide the card in at the correct orientation.
    • The gold pins should be on the bottom and you must line up the pin slot guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Rheo Bruer
회원 가입일: 02/05/19
973 평판
안내서 4개 작성하였습니다
댓글 7개
NOTE: Just FYI, once you have added another ram module to this laptop, and you turn it on, the screen may stay blank for up to a minute while the BIOS registers the new memory. Don’t panic if your screen does not come on right away. Give the BIOS time to update the new memory.
When I updated the ram in my Acer Nitro 5, the screen did not come on right away, and I thought it was a non compatible ram module, but this was not the case, just had to be patient.
The 300lb Gorilla - 답글
Can you take ram out of an aspire e15 and put in a nitro and have it work?
Casey O'Brien - 답글
I have a nitro 5, but it does not have the ram thing on the bottom of it. does the change what it looks like inside?
william - 답글
This guide refers to the 53-generation Nitro 5 (AN515-53) but I believe you are referring to the 54-generation (AN515-54). While they do not look exactly the same under the cover, they are very similar and the hardware is close to the same place and the RAM is installed using the same process.
Rheo Bruer -
ok thank you so much.so instead of the small cover I just take the bottom panel off.
william -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 19
30일 전: 71
전체 시간: 8,581
