주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-55G9 Speaker Replacement
필요한 것
  1. Acer Nitro 5 AN515-53-55G9 Speaker Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 5 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 5 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 7 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 7 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 3개
    • Once the battery is removed your device should look similar to this.
    • Locate the plug for the speakers located at the red circle.
  10. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 10 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • Unplug the cable from the motherboard as shown.
    • Carefully unroute the cables starting from the main plug.
    • Do not forcefully pull on the cable as it might break the cable.
  11. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 11 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 11 단계, 이미지 2개 중 2개
    • Pull up on the left speaker as shown here to remove the speaker from the device.
    • the rubber grommets from the speaker my pop off. These can easily be placed back on.
  12. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 12 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 12 단계, 이미지 2개 중 2개
    • Continue unrouting the cable from the device and following it to the right speaker.
    • Do not pull on the wire forcefully or it might break the cable.
  13. Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 13 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Speaker Replacement: 13 단계, 이미지 2개 중 2개
    • Locate the Right Speaker on the device.
    • Pull up on the speaker to remove from the device.
    • Rubber grommets from the speaker my pop off. These can easily be placed back on.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rheo Bruer
회원 가입일: 02/05/19
979 평판
안내서 4개를 작성함
댓글 한 개
Do you have an Android application?
DERDOURI TOUFIK - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 39
전체 시간: 7,391
