주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-55G9 Touchpad Replacement
필요한 것
  1. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: 1 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: 1 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 2 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 2 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 3 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 3 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 3 단계, 이미지 3/3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 5 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 5 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 5 단계, 이미지 3/3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 6 단계, 이미지 1/2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 6 단계, 이미지 2/2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
    One part you missed was to tell everyone that the HDD would still be attached to the back shell. I removed the shell and promptly ripped out my HDD cable. Now having to order a new cable…
    Mike Nitchie - 답글
  7. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 7 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 7 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 7 단계, 이미지 3/3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 8 단계, 이미지 1/1
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: 9 단계, 이미지 1/2 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement, Touchpad: 9 단계, 이미지 2/2
    • Locate the Touchpad in the lower middle of the device.
    • Locate and remove the 4mm screws that hold the Touchpad in place.
  10. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 10 단계, 이미지 1/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 10 단계, 이미지 2/3 Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 10 단계, 이미지 3/3
    • Locate the Touchpad's connector.
    • Use a plastic spudger to pry up the small plastic clip on the connector port.
    • Gently pull the cable out of the port.
  11. Acer Nitro 5 AN515-53-55G9 Touchpad Replacement: 11 단계, 이미지 1/1
    • Lift up the Touchpad and remove it from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Rheo Bruer
회원 가입일: 02/05/19
973 평판
안내서 4개 작성하였습니다
댓글 2개
And where can I find the track pad replacement? Thanks.
xRiiad _YouTube - 답글
You can purchase replacement trackpads online, on eBay or Amazon or many other places by simply Google searching “Acer Nitro 5 Touchpad Part”
Rheo Bruer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 30
전체 시간: 5,672
