주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement
필요한 것
  1. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2개 중 2개
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying it up with a plastic opening tool.
  3. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screw on the Hard Drive tray with a Phillips #0 screwdriver.
    • Lift up the tray covering using a plastic opening tool.
  4. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the fourteen 9mm screws holding the back cover in place.
    • Remove the hard drive (if applicable) from the slot prior to removing the back cover.
    • This device didn't have a hard drive so your device may look different.
  5. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the back cover off once all the clips have been disengaged.
  7. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 7 단계, 이미지 3개 중 3개
    • Using your fingers, disconnect the white and black cables connected to the left side of the Wi-fi card.
  8. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the screw holding down the Wi-Fi card with a Phillips #0 screwdriver.
  9. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 9 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the Wi-Fi card out from its port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
My hard drive got disconnected and I can't locate where is the place to connect it
manueltopete59 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 51
전체 시간: 6,924
