주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-55 SSD Replacement
필요한 것
  1. Acer Nitro 5 AN515-55 SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Shut down your laptop.
    • Make sure your laptop is completely turned off to prevent damaging other parts.
  2. Acer Nitro 5 AN515-55 SSD Replacement: 2 단계, 이미지 1/3 Acer Nitro 5 AN515-55 SSD Replacement: 2 단계, 이미지 2/3 Acer Nitro 5 AN515-55 SSD Replacement: 2 단계, 이미지 3/3
    • Flip the laptop on its back.
    • Remove the eleven 8 mm screws securing the back cover using the Phillips #1 screwdriver.
  3. Acer Nitro 5 AN515-55 SSD Replacement: 3 단계, 이미지 1/2 Acer Nitro 5 AN515-55 SSD Replacement: 3 단계, 이미지 2/2
    • Loosen the back cover using a plastic opening tool.
  4. Acer Nitro 5 AN515-55 SSD Replacement: 4 단계, 이미지 1/2 Acer Nitro 5 AN515-55 SSD Replacement: 4 단계, 이미지 2/2
    • Pull the back cover off and put it in a safe place.
    • A little bit of force is needed to pry open the clips at the corners of the laptop.
  5. Acer Nitro 5 AN515-55 SSD Replacement: 5 단계, 이미지 1/3 Acer Nitro 5 AN515-55 SSD Replacement: 5 단계, 이미지 2/3 Acer Nitro 5 AN515-55 SSD Replacement: 5 단계, 이미지 3/3
    • Remove the 2.6 mm screw that is holding down the SSD with a Phillips #0 screwdriver.
    • Make sure to ground yourself before working on the motherboard to prevent damage.
  6. Acer Nitro 5 AN515-55 SSD Replacement: 6 단계, 이미지 1/3 Acer Nitro 5 AN515-55 SSD Replacement: 6 단계, 이미지 2/3 Acer Nitro 5 AN515-55 SSD Replacement: 6 단계, 이미지 3/3
    • Gently pull out the damaged SSD.
  7. Acer Nitro 5 AN515-55 SSD Replacement: 7 단계, 이미지 1/2 Acer Nitro 5 AN515-55 SSD Replacement: 7 단계, 이미지 2/2
    • Slide in the new SSD.
    • Screw it in place.
  8. Acer Nitro 5 AN515-55 SSD Replacement: 8 단계, 이미지 1/2 Acer Nitro 5 AN515-55 SSD Replacement: 8 단계, 이미지 2/2
    • Put the back cover on and gently snap the clips back in.
    • Screw the back cover in place.
결론
Follow the guide that comes with your new SSD to make sure your laptop recognizes your new SSD.
다른 5명이 해당 안내서를 완성하였습니다.
Solomon Mekuria
회원 가입일: 03/22/21
271 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G14, Saloman Spring 2021 UMass Dartmouth, Team S3-G14, Saloman Spring 2021 회원
UMASSD-SALOMAN-S21S3G14
1 회원
안내서 1개 작성하였습니다
댓글 한 개
This model is supposed to have 3 slots 2 for SSD and 1 for HDD, can you please point them out? Just add an extra SDD?
mayumidb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 143
전체 시간: 8,047
