주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-55-53AG Internal Fan Replacement
필요한 것
  1. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Prior to beginning, be sure to turn off the device and unplug it from the power source.
    • Set the device on a flat surface with the vents facing upwards.
  2. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 2 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Use your Phillips #0 screwdriver to remove the eleven screws holding down the laptop's bottom cover.
  3. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 3 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 3 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Remove the laptop's bottom cover using an opening tool or plastic card.
    • Do not use a metal tool during this process. Doing so would risk damaging both the cover and the electrical components.
    • Be gentle during removal. Do not force the cover off, or it may break.
  4. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 4 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Detach the fan's wire connector from the motherboard.
  5. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Peel up the two strips of black tape holding the fan.
    • Do not peel the tape all the way off. Leave the tape attached to the heatsink.
  6. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 6 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 6 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two screws holding the fan in place using a Phillips #0 screwdriver.
    • Remove the old fan by pulling it directly up.
  7. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 7 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: 7 단계, 이미지 2개 중 2개
    • While the fan is out, clean the space with a cloth or a can of compressed air. Clean the fan vents and plate of any dust.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
на an515-55-534c система охлаждения так же разбирается ? или это он и есть ?
Антон Хабаров - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 100
전체 시간: 6,107
