주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-55-55M1 Fan Replacement
필요한 것
  1. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 2 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: 3 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: 3 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 4 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
  5. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Disconnect the seven cables from the motherboard using an iFixit opening tool.
  6. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 6 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 6 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
  7. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 7 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 7 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
    • Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
    • Lift the taped wires off of the fans on the right and left sides.
  8. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 8 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 8 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Lift up the right side of the motherboard.
    • The cables may need some guidance to leave the management holes on the motherboard.
    • Continue to lift at an angle until there is a give.
    • Remove the motherboard and fans from the laptop.
  9. Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: 9 단계, 이미지 3개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: 9 단계, 이미지 3개 중 2개 Acer Nitro 5 AN515-55-55M1 Fan Replacement, Fan: 9 단계, 이미지 3개 중 3개
    • Unplug the two fan connectors from each side of the motherboard using an opening tool.
  10. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 10 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Both fans are loose at this point and are only being held in by thermal tape.
    • Lift both fans up on each side and fold over the heat pipe.
  11. Acer Nitro 5 AN515-55-55M1 Fan Replacement: 11 단계, 이미지 2개 중 1개 Acer Nitro 5 AN515-55-55M1 Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the fan away from the heat pipe on both sides of the motherboard.
    • The tape will separate off of the heat pipe.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Samuel Rouillard
회원 가입일: 03/30/21
681 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-4, Mellen Spring 2022 UMass Dartmouth, Team 1-4, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S1G4
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 58
전체 시간: 1,728
