소개
This guide will show you how to remove the motherboard from an Acer Nitro AN515-55M1 laptop.
필요한 것
Make sure the device is off and unplugged from power.
Flip the device so the bottom is facing up.
Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
Lift up the right side of the motherboard.
Continue to lift at an angle until there is a give.
Remove the motherboard and fans from the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
