주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN515-57 RAM Replacement
필요한 것
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: 1 단계, 이미지 1/2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: 2 단계, 이미지 1/1
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: 3 단계, 이미지 1/2 Acer Nitro 5 AN515-57 RAM Replacement: 3 단계, 이미지 2/2
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: 4 단계, 이미지 1/2 Acer Nitro 5 AN515-57 RAM Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: 5 단계, 이미지 1/3 Acer Nitro 5 AN515-57 RAM Replacement: 5 단계, 이미지 2/3 Acer Nitro 5 AN515-57 RAM Replacement: 5 단계, 이미지 3/3
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: 6 단계, 이미지 1/1
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: 7 단계, 이미지 1/2 Acer Nitro 5 AN515-57 RAM Replacement: 7 단계, 이미지 2/2
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Hanzala Mir
회원 가입일: 01/17/22
170 평판
안내서 1개 작성함
York University, Team S-18, Woodhouse Winter 2022 York University, Team S-18, Woodhouse Winter 2022 회원
YORK-WOODHOUSE-W22SSG18
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 46
30일 전: 202
전체 시간: 4,613
