주요 콘텐츠로 건너뛰기
Acer Nitro 5 AN517-51-56YW Touch Pad Replacement
필요한 것
  1. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: 2 단계, 이미지 2개 중 1개 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: 3 단계, 이미지 2개 중 1개 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
  4. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: 4 단계, 이미지 2개 중 1개 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: 4 단계, 이미지 2개 중 2개
    • Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
    • Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
    • Lift the adhesive ribbon to be able to remove the touchpad.
    • Do not remove the ribbon completely, only the part that is on the touchpad.
  5. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: 5 단계, 이미지 2개 중 1개 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the touchpad towards you from the bottom.
결론
작성자
3다른 기여자 명과 함께
Giovanni Lopez
회원 가입일: 09/15/22
88 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 33
전체 시간: 429
