주요 콘텐츠로 건너뛰기
Acer One 10 S1002 145-A Battery Replacement
필요한 것
  1. Acer One 10 S1002 145-A Battery Replacement, Motherboard: 1 단계, 이미지 1/1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Battery Replacement: 2 단계, 이미지 1/2 Acer One 10 S1002 145-A Battery Replacement: 2 단계, 이미지 2/2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Battery Replacement: 3 단계, 이미지 1/3 Acer One 10 S1002 145-A Battery Replacement: 3 단계, 이미지 2/3 Acer One 10 S1002 145-A Battery Replacement: 3 단계, 이미지 3/3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Battery Replacement: 4 단계, 이미지 1/2 Acer One 10 S1002 145-A Battery Replacement: 4 단계, 이미지 2/2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Battery Replacement: 5 단계, 이미지 1/3 Acer One 10 S1002 145-A Battery Replacement: 5 단계, 이미지 2/3 Acer One 10 S1002 145-A Battery Replacement: 5 단계, 이미지 3/3
  6. Acer One 10 S1002 145-A Battery Replacement: 6 단계, 이미지 1/2 Acer One 10 S1002 145-A Battery Replacement: 6 단계, 이미지 2/2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Battery Replacement: 7 단계, 이미지 1/3 Acer One 10 S1002 145-A Battery Replacement: 7 단계, 이미지 2/3 Acer One 10 S1002 145-A Battery Replacement: 7 단계, 이미지 3/3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Battery Replacement: 8 단계, 이미지 1/1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Battery Replacement, Battery: 9 단계, 이미지 1/3 Acer One 10 S1002 145-A Battery Replacement, Battery: 9 단계, 이미지 2/3 Acer One 10 S1002 145-A Battery Replacement, Battery: 9 단계, 이미지 3/3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Shannon Griffin
회원 가입일: 10/03/16
1,372 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-3, Sullivan Fall 2016 USF Tampa, Team 1-3, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Thankyou for this information. I am replacing a battery on my own, and your tutorial is extremely clear and helpful.
shop_arod - 답글
I want a ..
Motherboard
4D Guru Channel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 23
30일 전: 76
전체 시간: 18,826
