Make sure that the tablet is turned off and disconnected from any power source.
Disconnect the tablet from the keyboard attachment.
If you have a Micro SD card in the tablet, remove it now.
Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Doing this, i’ve broke some of the “hook” thing that keepsthe plastic back plate to the screen, so now is loose and not well closed. How can I solve it?
I need motherboard for Acer one 10 s1001
Use the plastic opening tool to separate the glue that holds the battery to the screen.
Remove the battery and set it aside.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 2개
I want a ..
Motherboard
I don't find the screws
Andrea Spedaletti - 답글
