소개
If your tablet seriously malfunctions, (e.g. it is not turning on), a replacement motherboard may be needed. Motherboards in tablets are much smaller than traditional motherboards, and this guide shows you how to properly replace yours.
필요한 것
Make sure that the tablet is turned off and disconnected from any power source.
Disconnect the tablet from the keyboard attachment.
If you have a Micro SD card in the tablet, remove it now.
Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Doing this, i’ve broke some of the “hook” thing that keepsthe plastic back plate to the screen, so now is loose and not well closed. How can I solve it?
I need motherboard for Acer one 10 s1001
다른 12명이 해당 안내서를 완성하였습니다.
댓글 11개
WOW. Thank you so much for this guide. My keyboard wasn't connecting and last time I had to send it to Acer ...and that took a month. This time it is out of warranty and it wouldn't connect again!!!.... After opening it following this guide, it was immediately visible that the cable was out.
Thank you SO much!
Alen Mijic - 답글
put it aside and then?
Hey,
Whenever you see a 'put aside' anywhere in a guide there's an implied 'then continue' afterwards.
Hope that helps!
Great help. Was able to restore connection for my grandson’s computer using your clear concise directions. THANK YOU!!!
how can i fix my acer one s1002 keyboard dock it is not working if i connect it to the tablet i
me salvaste la vida! graciasss
Me salvaste la vida!!!!!!!!!!!
worked perfect to fix my daughters keyboard
OK, just out of warranty, 3 years from Costco, and went crazy trying to find out if a software upgrade left me disconnected. This video, and 15 minutes later, working again. The ribbon connector to the edge pins was the problem, lifted the black lock bar, pushed the ribbon cable back in position, and resnapped the black lock bar. A huge thanks for this video..
Thank you so much . My keyboard wasn't conneced and After opening it following this guide, it was immediately visible that the cable was out.
thank you so much
Any idea what the correct part number or spec for the power connector on the mother board is. Center pin was broken on parents and am trying to find replacement to get up and running for them.
I don't find the screws
Andrea Spedaletti - 답글
