소개
Is your battery is dead or weak, preventing it from powering your device? If so, here is a guide to fix the problem by removing and replacing your battery.
필요한 것
Make sure the device is turned off and disconnected from any power source.
To disconnect the tablet from the keyboard attachment, open the laptop and lift the tablet component up from the keyboard dock.
Starting from the corner of the tablet, use a jimmy to create a gap between the screen and the back covering.
Insert a metal spudger in the gap that you created with the Jimmy.
Slowly maneuver the metal spudger along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
다른 5명이 해당 안내서를 완성하였습니다.
