주요 콘텐츠로 건너뛰기
Acer One 10 S1003-114M Screen Hinge Replacement
필요한 것
  1. Acer One 10 S1003-114M Screen Hinge Replacement, Screen Hinge: 1 단계, 이미지 1/1
    • Open the screen.
  2. Acer One 10 S1003-114M Screen Hinge Replacement: 2 단계, 이미지 1/1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Screen Hinge Replacement: 3 단계, 이미지 1/2 Acer One 10 S1003-114M Screen Hinge Replacement: 3 단계, 이미지 2/2
    • Turn over the keyboard and use the plastic opening tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Screen Hinge Replacement: 4 단계, 이미지 1/3 Acer One 10 S1003-114M Screen Hinge Replacement: 4 단계, 이미지 2/3 Acer One 10 S1003-114M Screen Hinge Replacement: 4 단계, 이미지 3/3
    • Remove the ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Screen Hinge Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Screen Hinge Replacement: 6 단계, 이미지 1/1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Screen Hinge Replacement: 7 단계, 이미지 1/2 Acer One 10 S1003-114M Screen Hinge Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the electrical connector for the hinge. Pull gently while wiggling the connector back and forth.
    • Remove the adhesive tape holding the wire down.
  8. Acer One 10 S1003-114M Screen Hinge Replacement: 8 단계, 이미지 1/2 Acer One 10 S1003-114M Screen Hinge Replacement: 8 단계, 이미지 2/2
    • To free the hinge, remove the 4 mount screws with a Phillips #0 screwdriver.
  9. Acer One 10 S1003-114M Screen Hinge Replacement: 9 단계, 이미지 1/2 Acer One 10 S1003-114M Screen Hinge Replacement: 9 단계, 이미지 2/2
    • Remove the disconnected hinge from the keyboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Justin Bawinkel
회원 가입일: 04/01/19
327 평판
안내서 1개 작성함
IUPUI, Team S2-G6, Harley Spring 2019 IUPUI, Team S2-G6, Harley Spring 2019 회원
IUPUI-HARLEY-S19S2G6
4 회원들
안내서 2개 작성하였습니다
댓글 5개
Where can I buy the hinges of acer one 10 D16H1?
ladysam020889 - 답글
Do you know where I can find hinges of acer one s1003?
Al Monslisa - 답글
The hinge is so stiff it broke off the keyboard tabs. I need to loosen the hinge and replace the keyboard base, or hopefully just the positioning tabs (if they can be reglued).
PGI Cruiser - 답글
Tutoriel bien expliqué, merci pour tout, vous m’avez bien aidé à changer la charnière moi-même.
Francis Meylemans - 답글
Where can i buy new hinge for acer one s1003 , plss suggest me
Arvind - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 39
전체 시간: 6,246
