주요 콘텐츠로 건너뛰기
Acer One 10 S1003-114M Track Pad Replacement
필요한 것
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: 1 단계, 이미지 1/1
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: 2 단계, 이미지 1/1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: 3 단계, 이미지 1/2 Acer One 10 S1003-114M Track Pad Replacement: 3 단계, 이미지 2/2
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: 4 단계, 이미지 1/3 Acer One 10 S1003-114M Track Pad Replacement: 4 단계, 이미지 2/3 Acer One 10 S1003-114M Track Pad Replacement: 4 단계, 이미지 3/3
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: 6 단계, 이미지 1/1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: 7 단계, 이미지 1/1
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: 8 단계, 이미지 1/2 Acer One 10 S1003-114M Track Pad Replacement: 8 단계, 이미지 2/2
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: 9 단계, 이미지 1/2 Acer One 10 S1003-114M Track Pad Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: 10 단계, 이미지 1/3 Acer One 10 S1003-114M Track Pad Replacement: 10 단계, 이미지 2/3 Acer One 10 S1003-114M Track Pad Replacement: 10 단계, 이미지 3/3
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: 11 단계, 이미지 1/1
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: 12 단계, 이미지 1/1
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: 13 단계, 이미지 1/1
    • Gently remove the trackpad from the keyboard.
결론
Karan Karthik
회원 가입일: 04/01/19
217 평판
안내서 1개 작성함
IUPUI, Team S2-G6, Harley Spring 2019 IUPUI, Team S2-G6, Harley Spring 2019 회원
IUPUI-HARLEY-S19S2G6
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 23
전체 시간: 769
