주요 콘텐츠로 건너뛰기
Acer One 10 S1003-19GY Battery Replacement
필요한 것
  1. Acer One 10 S1003-19GY Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Acer One 10 S1003-19GY Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Battery Replacement: 2 단계, 이미지 1/1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Battery Replacement, Battery: 3 단계, 이미지 1/3 Acer One 10 S1003-19GY Battery Replacement, Battery: 3 단계, 이미지 2/3 Acer One 10 S1003-19GY Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Remove the two pieces of transparent yellow tape inside the device.
    • Using the Phillips #0 screwdriver, remove the two screws on either side of the connector.
    • Grab the the connector with tweezers and pull it slightly away from the motherboard.
  4. Acer One 10 S1003-19GY Battery Replacement: 4 단계, 이미지 1/2 Acer One 10 S1003-19GY Battery Replacement: 4 단계, 이미지 2/2
    • Flip the small black latch up on the connector where the ribbon inserts.
    • Gently pull the ribbon out of the connection.
    • Repeat this process on the upper orange ribbon connection.
  5. Acer One 10 S1003-19GY Battery Replacement: 5 단계, 이미지 1/2 Acer One 10 S1003-19GY Battery Replacement: 5 단계, 이미지 2/2
    • Peel back the black tape holding the battery in the three corners of the battery.
  6. Acer One 10 S1003-19GY Battery Replacement: 6 단계, 이미지 1/2 Acer One 10 S1003-19GY Battery Replacement: 6 단계, 이미지 2/2
    • Carefully pry the battery off of the adhesive on one side with a plastic spudger.
    • Remove the battery from the device.
    • We recommend to NOT use a metal spudger for this guide as a metal spudger can easily puncture lithium-ion batteries and cause further damage to yourself and the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trey Wintzinger
회원 가입일: 09/04/18
605 평판
안내서 5개 작성하였습니다
University of Alabama, Team S2-G8, Bedsole Fall 2018 University of Alabama, Team S2-G8, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S2G8
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Does anyone know where I can get a replacement battery and ship it to EU? Sadly, this Laptop doesnt turn on without the battery.
Nico V - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 28
전체 시간: 1,288
