주요 콘텐츠로 건너뛰기
Acer One 10 S1003-19GY WiFi Antenna Replacement
필요한 것
  1. Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: 1 단계, 이미지 1/2 Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY WiFi Antenna Replacement: 2 단계, 이미지 1/1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: 3 단계, 이미지 1/3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: 3 단계, 이미지 2/3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: 3 단계, 이미지 3/3
    • Disconnect the black ribbon connection attached to the motherboard.
    • Remove the chip fully by pulling the plastic tab on the left out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trey Wintzinger
회원 가입일: 09/04/18
605 평판
안내서 5개 작성하였습니다
University of Alabama, Team S2-G8, Bedsole Fall 2018 University of Alabama, Team S2-G8, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S2G8
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 680
