주요 콘텐츠로 건너뛰기
Acer Predator Helios 300 Battery Replacement
필요한 것
  1. Acer Predator Helios 300 Battery Replacement, Battery: 1 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement, Battery: 1 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Before you start make sure the laptop is grounded.
    • Make sure the laptop is powered off.
    • If the laptop is not turned off, there is a risk of electric shock when replacing the battery.
    • Close the cover of the laptop, then turn the laptop upside down so the back is facing up.
  2. Acer Predator Helios 300 Battery Replacement: 2 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement: 2 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement: 2 단계, 이미지 3/3
    • Remove all the screws from the back panel with a Phillips #0 screwdriver.
    • Remove the hard drive screw using a Phillips #0 screwdriver.
    • Use the panel tool to pop the storage hard disk open.
  3. Acer Predator Helios 300 Battery Replacement: 3 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement: 3 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement: 3 단계, 이미지 3/3
    • Remove the four screws mounted near the storage hard disk using a Phillips #0 screwdriver.
    • Disconnect the cable connected to the storage hard disk.
  4. Acer Predator Helios 300 Battery Replacement: 4 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement: 4 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement: 4 단계, 이미지 3/3
    • Use the panel tool to remove the back cover.
    • Slowly open the clips attached to the back cover, and store the cover safely.
  5. Acer Predator Helios 300 Battery Replacement: 5 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement: 5 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the tape holding the battery wires in.
    • Remove the two screws mounted next to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard slowly.
    • Remove the old battery.
  6. Acer Predator Helios 300 Battery Replacement: 6 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement: 6 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement: 6 단계, 이미지 3/3
    • The battery is a Household Hazardous Waste, so be sure to follow your city's laws and dispose of them properly.
    • Connect the new battery connector to the motherboard and screw it back with the screwdriver.
  7. Acer Predator Helios 300 Battery Replacement: 7 단계, 이미지 1/2 Acer Predator Helios 300 Battery Replacement: 7 단계, 이미지 2/2
    • Align the back cover with the laptop properly and click it with all the clips.
  8. Acer Predator Helios 300 Battery Replacement: 8 단계, 이미지 1/3 Acer Predator Helios 300 Battery Replacement: 8 단계, 이미지 2/3 Acer Predator Helios 300 Battery Replacement: 8 단계, 이미지 3/3
    • Insert the storage disk back in.
    • Connect it with the cable first and then fit it inside the missing space.
    • Fasten the remaining screws using a screwdriver.
결승점
Sidharth Rajeev
회원 가입일: 09/20/23
157 평판
안내서 1개 작성함
York University, Team O-30, O'Regan Winter 2024 York University, Team O-30, O'Regan Winter 2024 회원
YORK-O'REGAN-W24SOG30
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 33
30일 전: 203
전체 시간: 405
