주요 콘텐츠로 건너뛰기
Acer Predator Helios 300 Battery Replacement
필요한 것
  1. Acer Predator Helios 300 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you start make sure the laptop is grounded.
    • Make sure the laptop is powered off.
    • If the laptop is not turned off, there is a risk of electric shock when replacing the battery.
    • Close the cover of the laptop, then turn the laptop upside down so the back is facing up.
  2. Acer Predator Helios 300 Battery Replacement: 2 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement: 2 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove all the screws from the back panel with a Phillips #0 screwdriver.
    • Remove the hard drive screw using a Phillips #0 screwdriver.
    • Use the panel tool to pop the storage hard disk open.
  3. Acer Predator Helios 300 Battery Replacement: 3 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement: 3 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the four screws mounted near the storage hard disk using a Phillips #0 screwdriver.
    • Disconnect the cable connected to the storage hard disk.
  4. Acer Predator Helios 300 Battery Replacement: 4 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement: 4 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use the panel tool to remove the back cover.
    • Slowly open the clips attached to the back cover, and store the cover safely.
  5. Acer Predator Helios 300 Battery Replacement: 5 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement: 5 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the tape holding the battery wires in.
    • Remove the two screws mounted next to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard slowly.
    • Remove the old battery.
  6. Acer Predator Helios 300 Battery Replacement: 6 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement: 6 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • The battery is a Household Hazardous Waste, so be sure to follow your city's laws and dispose of them properly.
    • Connect the new battery connector to the motherboard and screw it back with the screwdriver.
  7. Acer Predator Helios 300 Battery Replacement: 7 단계, 이미지 2개 중 1개 Acer Predator Helios 300 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Align the back cover with the laptop properly and click it with all the clips.
  8. Acer Predator Helios 300 Battery Replacement: 8 단계, 이미지 3개 중 1개 Acer Predator Helios 300 Battery Replacement: 8 단계, 이미지 3개 중 2개 Acer Predator Helios 300 Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Insert the storage disk back in.
    • Connect it with the cable first and then fit it inside the missing space.
    • Fasten the remaining screws using a screwdriver.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sidharth Rajeev
회원 가입일: 09/20/23
211 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 66
지난 30일: 236
전체 시간: 2,396
