주요 콘텐츠로 건너뛰기
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
필요한 것
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: 1 단계, 이미지 1/2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: 1 단계, 이미지 2/2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 2 단계, 이미지 1/3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 2 단계, 이미지 2/3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 3 단계, 이미지 1/1
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: 4 단계, 이미지 1/2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: 4 단계, 이미지 2/2
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 5 단계, 이미지 1/2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 5 단계, 이미지 2/2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 6 단계, 이미지 1/1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: 7 단계, 이미지 1/2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: 7 단계, 이미지 2/2
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 8 단계, 이미지 1/1
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeffrey Kong
회원 가입일: 09/22/14
767 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-3, Forte Fall 2014 Cal Poly, Team 12-3, Forte Fall 2014 회원
CPSU-FORTE-F14S12G3
5 회원들
안내서 10개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 35
전체 시간: 2,423
