주요 콘텐츠로 건너뛰기
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
필요한 것
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: 1 단계, 이미지 2개 중 1개 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: 1 단계, 이미지 2개 중 2개
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 2 단계, 이미지 3개 중 1개 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 2 단계, 이미지 3개 중 2개 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: 4 단계, 이미지 2개 중 1개 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 5 단계, 이미지 2개 중 1개 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: 7 단계, 이미지 2개 중 1개 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: 7 단계, 이미지 2개 중 2개
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 8 단계, 이미지 1개 중 1개
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jeffrey Kong
회원 가입일: 09/22/14
885 평판
안내서 5개를 작성함
Cal Poly, Team 12-3, Forte Fall 2014 Cal Poly, Team 12-3, Forte Fall 2014 회원
CPSU-FORTE-F14S12G3
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 3,197
