주요 콘텐츠로 건너뛰기
Acer S200HL LCD Monitor Motherboard Replacement
필요한 것
  1. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: 1 단계, 이미지 1/2 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: 1 단계, 이미지 2/2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: 2 단계, 이미지 1/3 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: 2 단계, 이미지 2/3 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the edge of the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently lift back panel away from the monitor.
  4. Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: 4 단계, 이미지 1/2 Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: 4 단계, 이미지 2/2
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Motherboard Replacement: 5 단계, 이미지 1/2 Acer S200HL LCD Monitor Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Connections to the Motherboard: 7 단계, 이미지 1/1
    • The following steps circled in yellow are the locations for detaching the three connectors shown in the picture.
  8. Acer S200HL LCD Monitor Motherboard Replacement, Removing the No Fuss Ribbon Cable Connector: 8 단계, 이미지 1/1
    • Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
    • The connector will be released from the motherboard immediately.
  9. Acer S200HL LCD Monitor Motherboard Replacement, Removing the ZIF Connectors: 9 단계, 이미지 1/1
    • Lift the black seal to release the large ribbon connector (the ZIF connector).
  10. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Bundled Cable Connector: 10 단계, 이미지 1/1
    • Pull the bundled cable connector gently away from motherboard.
  11. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Motherboard: 11 단계, 이미지 1/1
    • Gently lift the motherboard to remove it from the monitor.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jeffrey Kong
회원 가입일: 09/22/14
767 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-3, Forte Fall 2014 Cal Poly, Team 12-3, Forte Fall 2014 회원
CPSU-FORTE-F14S12G3
5 회원들
안내서 10개 작성하였습니다
2 댓글
como saber si es la board o las lamparas q trae la pantalla?
y cual es la forma de reparar las lamparas
Doc acvdo - 답글
What is the specific name of that dc-in power jack?I’ m trying to replace that thing with a new one,the current one is already faulty.Can u recommend me where to find that part?Thanks!
Oreo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 32
30일 전: 84
전체 시간: 6,227
