소개
The ZIF connector is an important electronic connection between the motherboard and the monitor screen.
필요한 것
Place the monitor screen face down.
Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
Pull the stand away from the monitor.
다른 한 분이 해당 안내서를 완성하였습니다.
2 댓글
My model (Acer S220HQL) looks similar, but the motherboard (in its casing) was attached to the back of the screen with adhesive tape, not screws!
My problem was with the LED backlights. They often did not light up, or they switched off when I tried to alter the screen configuration (I am using it as a second monitor). Although the blue light was on, the screen went completely blank. The problem occurred with both a DVI and a D-sub connection to the PC.
After following the instructions as closely as I could, fixing the motherboard with 4 instead of 2 screws, and re-assembling, the monitor is working well. I can't think of what problem was--maybe an earth connection was broke.
-- Thanks for the instructions, they have saved my monitor until I next need to tinker with it!
What is the size of the dc in of the monitor?
