주요 콘텐츠로 건너뛰기
Acer Spin 3 SP315-51-757C Back Panel Replacement
필요한 것
  1. Acer Spin 3 SP315-51-757C Back Panel Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Back Panel Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Back Panel Replacement: 2 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Back Panel Replacement: 2 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Back Panel Replacement: 2 단계, 이미지 3/3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Back Panel Replacement: 3 단계, 이미지 1/1
    • Lift the back panel off of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Skyler Ognibene
회원 가입일: 09/17/19
934 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 16
전체 시간: 1,918
