소개
In order to replace any parts inside the Acer Spin 3 SP315-51-757C, you will have to remove the back panel first. This guide can be completed very quickly and easily, as you will only need to remove some screws with a Phillips #0 screwdriver and pull the panel off the laptop using a plastic opening tool.
필요한 것
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
