주요 콘텐츠로 건너뛰기
Acer Spin 3 SP315-51-757C Hard Drive Replacement
필요한 것
  1. Acer Spin 3 SP315-51-757C Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Hard Drive Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 2 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 2 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 2 단계, 이미지 3/3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 3 단계, 이미지 1/1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Loosen the single Phillips #0 screw holding the hard drive in place.
  5. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 5 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 5 단계, 이미지 2/2
    • Gently lift the closer side of the hard drive out of its slot.
    • Make sure not to pull too hard on the cables plugged into the motherboard.
  6. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 6 단계, 이미지 1/1
    • Carefully unplug the cable connected to the side of the hard drive.
  7. Acer Spin 3 SP315-51-757C Hard Drive Replacement: 7 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Skyler Ognibene
회원 가입일: 09/17/19
934 평판
안내서 6개 작성하였습니다
댓글 2개
Awesome. Thanks for the tips here. Do you have any recommendations on what SSD may go with Acer Spin 3 SP315-51-757C ? I am a little clue less here since i am new to this, and any feedback here would help. Thanks.
S B - 답글
I just replaced my HDD with a 1TB Crucial MX500 SSD. It was easy to clone the drive and simple to install. My computer went from almost unusable to better than new, I highly recommend it.
Adam Kahler -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 34
전체 시간: 4,395
