주요 콘텐츠로 건너뛰기
Acer Spin 3 SP315-51-757C Screen Replacement
필요한 것
  1. Acer Spin 3 SP315-51-757C Screen Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Screen Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Screen Replacement: 2 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Screen Replacement: 2 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Screen Replacement: 2 단계, 이미지 3/3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Screen Replacement: 3 단계, 이미지 1/1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Screen Replacement, Battery: 4 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Screen Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Screen Replacement: 5 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Screen Replacement: 5 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Screen Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Screen Replacement: 6 단계, 이미지 1/1
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
  7. Acer Spin 3 SP315-51-757C Screen Replacement, Charger Port: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • The charger port's inner cable may be covered by a manufacturer sticker, which can be easily removed.
    • Using your nails or tweezers, unplug the charger port cable from the motherboard.
  8. Acer Spin 3 SP315-51-757C Screen Replacement: 8 단계, 이미지 1/1
    • Gently lift the charger port out of its slot in the laptop casing.
  9. Acer Spin 3 SP315-51-757C Screen Replacement, Motherboard: 9 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Screen Replacement, Motherboard: 9 단계, 이미지 2/2
    • Lift the three black tabs to release the cable connectors.
    • After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
  10. Acer Spin 3 SP315-51-757C Screen Replacement: 10 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Screen Replacement: 10 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Screen Replacement: 10 단계, 이미지 3/3
    • Remove the cables near the fan by pulling them carefully out of their slots.
  11. Acer Spin 3 SP315-51-757C Screen Replacement: 11 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Screen Replacement: 11 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Screen Replacement: 11 단계, 이미지 3/3
    • Remove the single Phillips #0 screw.
    • Unplug the speaker cable.
    • Unplug the secondary speaker cable.
  12. Acer Spin 3 SP315-51-757C Screen Replacement: 12 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Screen Replacement: 12 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Screen Replacement: 12 단계, 이미지 3/3
    • Remove the three Phillips #0 screws attached to the motherboard.
  13. Acer Spin 3 SP315-51-757C Screen Replacement: 13 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Screen Replacement: 13 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove four screws from the heat sink.
    • Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
  14. Acer Spin 3 SP315-51-757C Screen Replacement, Screen: 14 단계, 이미지 1/1
    • Remove the screws from the "L" and "R" plastic pieces using a Phillips #0 screwdriver.
  15. Acer Spin 3 SP315-51-757C Screen Replacement: 15 단계, 이미지 1/1
    • Remove four screws from the metal hinges in the corners using a Phillips #0 screwdriver.
  16. Acer Spin 3 SP315-51-757C Screen Replacement: 16 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Screen Replacement: 16 단계, 이미지 2/2
    • Using an opening tool, separate the bezel from the rest of the device.
  17. Acer Spin 3 SP315-51-757C Screen Replacement: 17 단계, 이미지 1/1
    • Remove the Phillips #0 screws attaching the screen to the display assembly.
  18. Acer Spin 3 SP315-51-757C Screen Replacement: 18 단계, 이미지 1/1
    • Using your hands, remove the screen.
결론
Mikey Kreuzer
회원 가입일: 02/08/24
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 37
