주요 콘텐츠로 건너뛰기
Acer Spin 3 SP315-51-757C Trackpad Replacement
필요한 것
  1. Acer Spin 3 SP315-51-757C Trackpad Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Trackpad Replacement: 2 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 2 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 2 단계, 이미지 3/3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Trackpad Replacement: 3 단계, 이미지 1/1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Trackpad Replacement, Battery: 4 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Trackpad Replacement: 5 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 5 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Trackpad Replacement: 6 단계, 이미지 1/1
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
  7. Acer Spin 3 SP315-51-757C Trackpad Replacement, Charger Port: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • The charger port's inner cable may be covered by a manufacturer sticker, which can be easily removed.
    • Using your nails or tweezers, unplug the charger port cable from the motherboard.
  8. Acer Spin 3 SP315-51-757C Trackpad Replacement: 8 단계, 이미지 1/1
    • Gently lift the charger port out of its slot in the laptop casing.
  9. Acer Spin 3 SP315-51-757C Trackpad Replacement, Motherboard: 9 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Motherboard: 9 단계, 이미지 2/2
    • Lift the three black tabs to release the cable connectors.
    • After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
  10. Acer Spin 3 SP315-51-757C Trackpad Replacement: 10 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 10 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 10 단계, 이미지 3/3
    • Remove the cables near the fan by pulling them carefully out of their slots.
  11. Acer Spin 3 SP315-51-757C Trackpad Replacement: 11 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 11 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 11 단계, 이미지 3/3
    • Remove the single Phillips #0 screw.
    • Unplug the speaker cable.
    • Unplug the secondary speaker cable.
  12. Acer Spin 3 SP315-51-757C Trackpad Replacement: 12 단계, 이미지 1/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 12 단계, 이미지 2/3 Acer Spin 3 SP315-51-757C Trackpad Replacement: 12 단계, 이미지 3/3
    • Remove the three Phillips #0 screws attached to the motherboard.
  13. Acer Spin 3 SP315-51-757C Trackpad Replacement: 13 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement: 13 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove four screws from the heat sink.
    • Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
  14. Acer Spin 3 SP315-51-757C Trackpad Replacement, Heat Sink and Fan: 14 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the three screws that hold the fan on top of the motherboard.
  15. Acer Spin 3 SP315-51-757C Trackpad Replacement: 15 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the four screws that connect the heat sink to the motherboard.
  16. Acer Spin 3 SP315-51-757C Trackpad Replacement: 16 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement: 16 단계, 이미지 2/2
    • Remove both the fan and the heat sink with your hands.
  17. Acer Spin 3 SP315-51-757C Trackpad Replacement, Hard Drive: 17 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Hard Drive: 17 단계, 이미지 2/2
    • Loosen the single Phillips #0 screw holding the hard drive in place.
  18. Acer Spin 3 SP315-51-757C Trackpad Replacement: 18 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement: 18 단계, 이미지 2/2
    • Gently lift the closer side of the hard drive out of its slot.
    • Make sure not to pull too hard on the cables plugged into the motherboard.
  19. Acer Spin 3 SP315-51-757C Trackpad Replacement: 19 단계, 이미지 1/1
    • Carefully unplug the cable connected to the side of the hard drive.
  20. Acer Spin 3 SP315-51-757C Trackpad Replacement: 20 단계, 이미지 1/2 Acer Spin 3 SP315-51-757C Trackpad Replacement: 20 단계, 이미지 2/2
    • Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
  21. Acer Spin 3 SP315-51-757C Trackpad Replacement, Keyboard: 21 단계, 이미지 1/1
    • Remove the plastic rivets individually using a spudger.
  22. Acer Spin 3 SP315-51-757C Trackpad Replacement: 22 단계, 이미지 1/1
    • Swipe a spudger underneath keyboard to unlock it from its frame.
  23. Acer Spin 3 SP315-51-757C Trackpad Replacement: 23 단계, 이미지 1/1
    • Use the spudger to pry the keyboard up and away from the laptop.
  24. Acer Spin 3 SP315-51-757C Trackpad Replacement, Trackpad: 24 단계, 이미지 1/1
    • Remove all the plastic rivets with a spudger.
  25. Acer Spin 3 SP315-51-757C Trackpad Replacement: 25 단계, 이미지 1/1
    • Remove the bottom metal bar with your hands.
  26. Acer Spin 3 SP315-51-757C Trackpad Replacement: 26 단계, 이미지 1/1
    • Remove the trackpad by pressing upwards from the bottom.
결론
Kylie Ann
회원 가입일: 02/08/24
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 33
