소개
Is your device not properly loading files? Are the files in your device “corrupted” or “inaccessible”? If so, the hard drive may be faulty and needs to be replaced. Follow the instructions in this guide to remove and replace the hard drive in the Acer Spin 3 SP315-51-79NT laptop.
필요한 것
Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
Unplug the ribbon connectors by lifting the little flap on the top of the adapter then pull them out.
다른 3명이 해당 안내서를 완성하였습니다.
